Hit Decay constantly changing/updating
plbrunet
Post by plbrunet »
Hi there,
I'm running DSP Trigger version 1.6.1 build 6 on Mac OS 10.15.7 and the Hit Decay is constantly moving even when not in calibrate mode.
My problem with that is that I'm using a microphone and all continuous external sound keep triggering the midi and I want to avoid that.
Here is a video showing this behaviour.
https://photos.app.goo.gl/heXLERF6XUDhJVMZ7
Is there a way to avoid this?
Thanks!
Re: Hit Decay constantly changing/updating
It's working as expected. You can try relaxing the hit decay, but DSP TRIGGER is just doing its job. Maybe you could have a mute button for you microphone?
plbrunet
Post by plbrunet »
My question is, should the Hit Decay constantly change by itself? Even when it's not in calibration mode?
I tried changing the hit decay but as soon as DSP trigger receive a sound, it updates and changes the hit decay I setup.
It's not actually changing. It gets scaled according to the calculated velocity.
plbrunet
Post by plbrunet »
Hmm ok, I may have to find another solution.
Thank you Rob.
