CC switch in gesture mode
MauriceWCashman
Post by MauriceWCashman »
Rob,
I like the upgrade on midi expression using the expression pedal for a switch as well. However, when I go into it on my MacBook it doesn't have the option like how it is shown in your video. I have downloaded the latest build, so I didn't know if that was a something that wasn't available on Mac or not.
Thanks,
Maurice
Re: CC switch in gesture mode
It's not available for first generation MIDI Expressions (with the mini USB connector). How old is your device?
MauriceWCashman
I've bought multiple devices but it looks like the last one I bought was 7/29/2020.
I'm not sure of the exact date, but anything purchased after 2016 should be supported. I just tested on PC and MAC and everything looks in order here using version 2.8.5.18.
Screenshot 2021-03-01 213124.png (31.9 KiB) Viewed 696 times
MauriceWCashman
Yes, sorry I was just missing the setup screen to change the function over. Thanks for the screenshot, that reminded me how to set it up.
