log pot curve
janner
log pot curve
Post by janner »
hello,
I'm wondering if the MIDI Expression Control software is suitable to correct the response curve of a volume pedal with a logarithmic pot to make it completely linear.
many thanks.
Re: log pot curve
Possibly. It might not do it perfectly, but I suspect you could definately get something close.
janner
Re: log pot curve
Post by janner »
that's good news, thank you. close to perfect should be good enough. thanks!
