Different profiles?
Malcatraz
Different profiles?
Post by Malcatraz »
Would it be possible (or is it possible) to create different profiles that we can switch between on the control app? I use Addictive Drums 2 and BFD3, and it would be great to be able to instantly go from one to the other and have all the settings change accordingly.
Re: Different profiles?
Sure, there are 4 MIDI banks, so you can program one bank for AD2, and another for BSD.
perceval wrote:Sure, there are 4 MIDI banks, so you can program one bank for AD2, and another for BSD.
And if you add a simple footswitch, you can use it to switch banks for all inputs at once.
Malcatraz
Post by Malcatraz »
Ah good call....I hadn’t thought of the midi banks. I have an old Roland FD-6 I could use as a footswitch too. Thanks fellas!
