weight not clear of modules
CapCrunch
Post by CapCrunch »
The weight is listed in mm on your specs page. Is that grams? Could you say what the weight is? I'm assuming the L,Width, H are correct? Thanks
Length 88 mm 115 mm
Width 71 mm 90 mm
Height 26 mm 36 mm
Weight 89 mm 325 mm
Re: weight not clear of modules
Yes, those units should be grams. I'll fix it. Thanks for pointing out the mistake.
