Which assigned MIDI Notes does the 10 input use?
dlamb8989
Post by dlamb8989 »
Hello, I am looking to purchase the 10 input model, and want to know what MIDI note numbers get assigned for the 10 inputs. For example, my current module uses 43-48 for toms. So. I'm looking to know which numbers the 10 input module will use up. Thanks !
Re: Which assigned MIDI Notes does the 10 input use?
You can setup them.to whichever notes you want. There are also drum maps integrated into UI to support Roland, Yamaha, SD3, BFD3, and others.
