Safe to leave unit on indefinitely, or best to turn off after every use
Gemini8026
Post by Gemini8026 »
Curious for Rob or any other tech people out there. Obviously this isnt a power hungry unit, but there is some processing onboard. My E-drumin is located under my set so its a bit of a hassle turning it on and off. Anybody have any input on whether its safe to leave unit on constantly, or do you turn off?
Re: Safe to leave unit on indefinitely, or best to turn off after every use
For what it's worth, I've had my ED10 since early August and I never turn it off. Never had a problem.
I leave mine on all the time too. The only situation I would advise against leaving the unit powered is if you are using the 9v DC connector and have a high current draw USB device plugged into the host port.
