How can I adjust crosstalk (What does the knob do)
Rotil66
Post by Rotil66 »
Hi All,
I just received my Edrumin10 yesterday (Thank Rob for the correct and speedy shipping !!!)
I allready fall in love with the options. I have been playing around with al kinds of Modules and Pad's (Also DIY)
I'm using a TD12 and Edrumin to trigger Superior drummer 3 om my minimac. All is running great with extreem low latency..
I'm familiair with Crosstalk suppresion in my TD-12 etc. But I not quite understand (Also little info to find) how this can be adjusted in the Edrumi software. I have 1 tom (Connected to my TD-12 and midi out running thru the Edrumin10)
That is causing some crosstalk to some cymbals (Directly connected to my Edrumin) So how can I suppress this crosstalk for this specific Tom / Cymbals...
In the manual I can't find what the knob is actually doing. Specially on how the incomming midi info interacts with the direct connected pads.
Thanks !!!
Re: How can I adjust crosstalk (What does the knob do)
The amount of crosstalk cancellation from external MIDI applied to pads connected to the ED10 is currently fixed because controls haven't been implemented in the UI.
I'll flesh this out in version 1.5. Maybe in a month or two from now.
