eDRUMin 1.4 BETA is now available. Use at own risk. Downgrading from 1.4 back to 1.3 will cause your device to factory reset. At this point I advise against overwriting any of your user presets in case you need to downgrade. I will maintain links to the latest version below. As always, I appreciate feedback and bug reports.
PC
https://www.audiofront.net/eDRUMin_Cont ... 4.0.38.zip
macOS
New Features
  • Standard / Advanced mode.
  • Note Banks for Hihat.
  • Drum Maps for hihat notes.
  • Separate Velocity Curves for each articulation.
Changes and Improvements
  • Articulation scalers now go down 0.5.
  • Auto-Select is no longer disabled for 3 seconds after an edit is made.
  • The second input for a Roland 3-Zone cymbal can now be used in DUAL Mono mode.
  • Reduced the amount of hihat position filtering.
  • Most FSR type hihat controllers can now be connected with TS (mono) cables.
  • More reliable pedal sensing.
Bug Fixes since version 1.3
  • Fixed an issue when connecting USB2 MIDI devices to the USB host port.
  • Fixed an issue that would cause too much crosstalk cancellation to be applied to xstick articulations.
  • MIDI data from pedals is now forwarded to MIDI devices connected to the host port.
  • Fixed issues changing banks of devices connected to the USB host port.
  • Fixed UI locking up on Windows when multiple eDRUMins were connected.
  • Fixed 'invert' for pedal 2 of ED10.
  • Fixed adjusting the right side of the calibration range turns 'sense' on
  • Fixed issues with the pedal calibration control and process.
Changes in build 38
  • Fixed Choke Note not being sent to MIDI Out DIN.
  • Fixed export preset icon not displaying properly.
Changes in build 37
  • Fixed auditioning note assignments not being send to USB Host Port devices.
  • Fixed auditioning note assignments not using using MIDI channel from Note Banks.
  • Fixed RS/SS/BELL not using main velocity curve when no independent curve is assigned.
  • Fixed typo in Drum Map selector.
Changes in build 35
  • Fixed sidestick might send wrong note when using positional sensing set to send notes (not CC).
  • Updated default settings for ED4R2.
  • Increased the size of the calibration range control.
  • Fix an issue that would cause firmware updates to take longer than expected.
Changes in build 32
  • Fixed velocity curve data becoming corrupt when overwriting a preset.
  • Fixed peek indicators on VU not working for cymbals.
  • Small UI feedback improvement for Rimshot Range control,
  • Various UI fixes.
  • Selected articulation can no longer automatically change when a control is being dragged.
Changes in build 30
  • Fixed an issue in the last few builds that could prevent ED10 from properly detecting another eDRUMin in the USB Host port.
Changes in build 29
  • Right-Clicking a note control will toggle notes/numbers for all note controls and setting is saved between sessions.
  • Adjusting the curve for an articulation will automatically set it to 'independent'.
  • Improved behavior of tool tips for knobs and faders.
  • Adjusted default settings for hihats.
Changes in build 28
  • Brought back support for macOS version down to 10.7.
Changes in build 27
  • Fixed a display issue with the 'Polarity' control.
Changes in build 26
  • MIDI from USB MIDI in will now be forwarded to MIDI out / USB Host port.
Changes in build 24
  • Uncalibrated hihat pedals are now auto-calibrated.
Changes in build 23
  • Fixed adjusting the right side of the calibration range turns 'sense' on.
  • Yamaha hihats can now be properly calibrated.
Changes in build 22
  • Pedal Sensing fixes.
  • Fixed positional CC not being sent to Host Port.
  • Fixed auto-select issue.
  • Updated Manual.
Changes in build 21
  • Cosmetic fixes.
Changes in build 20
  • Fixed support for VH-11 (regression bug).
Changes in build 19
  • Fixed current pedal calibration not updated when clicking the 'calibrate' button.
  • Fixed UI feedback for hihats set to use 'impact' method.
Changes in build 17
Changes in build 16
  • Fixed an issue with changing hihat MIDI assignments in 'standard' mode.
Changes in build 15
  • Fixed aftertouch not being sent to USB host port.
  • Fixed issues using a pedal to change banks of devices connected to USB host port.
Changes in build 12
  • Fixed as issue where pedal MIDI wasn't being sent to the host port when not connected to a computer.
  • Fixed an issue with font size of drum map selector.
  • Updated User Manual.
Changes in build 11
  • Some types of Hall Effect sensors (not externally powered) can now be detected when 'sense' is enabled.
  • FSRs will now be detected when using a (TS) mono cable and 'sense' in enabled.
  • Fixed an issue synchronizing HH notes banks when switching banks with a footswitch or sustain pedal.
  • Fixed a display issue when plugging in a second pedal when the first pedal is selected.
  • Possibly? fixed a random crash in macOS.
Changes in build 10
  • Fixed an issue that would prevent some hall effect sensors from being powered.
  • Host port can now handle class compliant MIDI devices with descriptors as large as 1K (iConnectivity devices).
  • MIDI data from pedals is now filtered during calibration.
  • If not using 'sense', FSR based hihat pedal can now be connected using a TS (mono) cable.
Changes in build 9
  • Fixed hihat gain changing after loading a hihat drum map.
  • Title bar in macOS UI now correctly reads 'eDRUMin'.
Changes in build 8
  • Fixed an issue with the pedal input when 'sense' was turned off (regression bug).
  • Fixed a calibration issue.
Changes in build 7
  • New pedal sensing method to improve reliability (should resolve issue with VH-12).
  • Fixed an issue with selected input changing even when autoselect is off.
  • Fixed an issue with default hihat note bank value when updating from version 1.3.
  • Changed the default hihat pedal calibration to work better with VH-10/12/13.
Changes in build 5
  • USB Host port now properly support USB2 MIDI devices.
  • ED10 will properly supply power for pedals again (regression bug)
  • Fixed a display issue when switching between a hihat pedal and a footswitch.
Changes in build 4
  • Fixed issues with note banks for the hihat pedal.
Changes in build 3
  • Forgot to turn off a debugging information for the pedal input.
Changes in build 2
  • Fixed an issue that would prevent hihats from working when using 'standard' mode.
There's a text button above the velocity curve area to switch between standard (default) and advanced mode. The idea here is to make the device easier to use for new users. In standard mode, note banks, velocity curves, and hihat impact mode are disabled. This setting is stored on the device, and not in the UI. When operating in standard mode, the device will always use bank 1, and all articulation will use the first velocity curve.
When in advanced more, there are two icons to switch between adjusting curves and editing bank assignments. This was done in order to add the new functionality without needing to completely redesign the UI or add too much confusing clutter.
Bell input and Dual Mono Mode
Roland 3-Zone rides and 3-Zone metal cymbals can now have their bell inputs on an input that is set to Dual Mono. Make sure you change the input that is destined to be the bell to dual mono mode first. The wiring gets pretty complicated, IMH. I had to split the output of my CY-15 BOW/BELL input, and then feed the BELL input into another splitter which was used to merge the BELL and the piezo of another pad together.
Velocity Curves for each Articulation
Each articulation can now have and independent velocity curve (Ind checkbox). You'll need to be in advanced mode.
Note Banks for hihat Pedal
Note banks are only available when in Note Mode or Hihat mode. There's no way to use a footswitch to directly change the bank of the hihat pedal. Assuming it is properly linked to a trigger input, when the bank of the linked trigger input changes, so does the bank of the hihat pedal.
A word about presets
Presets created in earlier versions will not be changed. They will be upgraded on the fly. Don't overwrite your presets if you plan to downgrade from version 1.4 Downgrading from version 1.4 will cause your device to factory reset, and those presets can be used to restore your settings.
Versions of OSX < 11.12
I've recently upgraded my development machine to Big Sur. Unfortunately, APPLE has dropped support for versions of OSX < 11.12. In the coming weeks I will downgrade my system back to Catalina so that I can bring back support for OSX 11.8 - 11.11.
thanks, Rob!
Sly
Post by Sly »
I really like the independant curve for each note and scaler going down to 0.5. Thanks Rob
I found that the autoselect is still active even when deselected.
Sly
Post by Sly »
I don't know if it's intentionnal, but the Side Stick scaler don't go under 1, unlike the Rimshot scaler.
That's intentional. Thanks.
Sly
Post by Sly »
Deleted... I was looking for the note banks... Found.
Thanks for the update. I hope the ankle feels better soon.
Thanks, Mylo. I'm couch ridden for a few days. My wife is not impressed.
Bummer... well I hate to post the first bug but my X-Stick scalers are off. Most likely a math issue.
Nope, at least not if you're talking about the display. Now they are correct. Does it feel like the responsiveness has changed?
