Flaky software not working well
punkouter2021
Post by punkouter2021 »
When I load the Edrumin10 sometimes it loads as a eDrumin4 with only the 4 icons.. besides that when I hit triggers and expect the screen to change often gets stuck..
Anyone else have this happening to them??
Re: Flaky software not working well
Give the latest version a try (1.3.2.19). Let me know if it resolves your issues.
Happened to me on the very first versions of the software, but nothing like what is mentioned in the OP post for quite some time now.
punkouter2021
ok got it.. Ill foloow up here if I get the same problem...
small thing I notcied so far The icon is incorrect for one of the inputs after I changed it.. the acoustic trigger looks like a hihat icon
punkouter2021 wrote:ok got it.. Ill foloow up here if I get the same problem...
It'll show that if linked to a pedal input.
Just to give a little more help on the hi-hat icon. I got tripped up by that when Rob first introduced the feature. You need to link the input your hi-hat cymbal is plugged into in the hi-hat pedal setup page. I'm going by memory but I think you select the input you have your hi-hat cymbal plugged into and then you click the link button. It will turn from whatever icon it is to the hi-hat icon.
This is more than a cosmetic feature - their is a cross talk dampening feature that is helpful if you stand is an actual hi-hat stand that might be picking vibrations from the pedal actions.
