Ghost Note 73 edrumin original
Impulseblue06gto
Post by Impulseblue06gto »
I am currently using a td11 roland module and also an edrumin the issue i am having in superior drummer 3 is that i am getting ghost notes from note 73 with hi hat articulations i can only guess that whatever map the edrumin is using for the hi hat articulations is triggering this note currently deleting this floor tom rimshot is the work around but looking for a full solution, the hi hat is running through the edrumin a china and poistional snare.
thenewdrummer
Re: Ghost Note 73 edrumin original
Post by thenewdrummer »
I'm not sure if I understood completely the problem but did you try to change the note that is sent in edrumin? You can change the value without the drum map.
