PD-120 and Hotspot Suppression
TheStewards
Post by TheStewards »
Howdy. I started calibrating my eDRUMin10 today, and I’m happy with my progress so far.
I am having some issues with two PD-120s I recently acquired. For both pads, hotspot suppression seems to be engaged right as I begin to calibrate but then essentially shuts off, failing even to register and/or display hits on the Thresh meter.
Rob or others, any thought on what I’m facing here? I know that monospace uses this pad successfully, so I’m confident that it can work. I had a look at the other thread about this functionality and the problem a poster faced when the signal from his DIY build was too hot, and I’m beginning to wonder whether these particular pads have been refurbished with new piezos, cones, or both, and if so, whether those could cause an issue.
In any case, I’d appreciate any advice here. Thanks!
