Preset: Roland VH-10
Forum rules
Preset for the Roland VH-10 hihat cymbal trigger (this should also work reasonably well with a VH-11)
Roland_VH10.edp.zip
(343 Bytes) Downloaded 365 times
arryboy
Re: Preset: Roland VH-10
Post by arryboy »
HI Been looking to find out out how you enter presets into Edrumin10 could you help Thnks
