Preset: Roland KD-8
Forum rules
Preset: Roland KD-8
Preset for the Roland KD-8 kick tower (mono, rubber pad, using a Kat Silent Strike beater, so "Gain" is relatively high)
Roland_KD8.edp.zip
(332 Bytes) Downloaded 285 times
