Preset: Roland CY-14
Forum rules
Preset for the Roland CY-14 cymbal pad
Roland_CY14.edp.zip
(337 Bytes) Downloaded 419 times
Re: Preset: Roland CY-14
Does it support bell sense?
Probably. Try the CY-13 or CY-15 bell sense setting.
Yes, the CY-15 works best and with 75 value, this preset is on CY-8 mode and 47 value is rather clunky
Interesting, I keep asking for more info on these presets, because in my experience, “CY-8” is the most reliable preset, “CY-15” only works on my CY-15, and “CY-13” barely works on my CY-13 and nowhere else. When I select “CY-15” for my CY-14 at 75, I get no bell sound at all. :geek:
I found a bug with the CY-13 algorithm today...
fconstan
Post by fconstan »
monospace wrote:
Thu Aug 05, 2021 11:30 pm
Same here, are you able to use bell sense using the CY-14 ?
fconstan wrote:
Tue Feb 27, 2024 10:31 am
That was a post from 2 1/2 years ago, lots of things have been fixed since then. My old CY-14 works fine these days, using the CY-8 preset at 76. Honestly, I have no idea why a certain preset works with a certain model and not with others. I just try them all and once I get the cymbal to work, I just leave it alone.
