Potentiometer test
ohm-ish
Potentiometer test
Post by ohm-ish »
Hi
I got a potentiometer, and would like to use it to test some things on the eDRUMin.
Like a hihat open/close or just to control some midi.
Could I use the hi-hat connection on the eDRUMin directly?
I mean just wire up the potentiometer, nothing else.
Re: Potentiometer test
Yes. The potentiometer must be between 10k and 100k ohms. Look in the manual for wiring diagrams.
ohm-ish
Post by ohm-ish »
Great, thanks
