GoEdrum like HH Controler + Yamaha PCY-135 possible?
anton
Post by anton »
Hi friends,
just wanted to ask if the in the subject mentioned combo would work, especially with the eDRUMin.
That would be quite a cheap HH solution with 3 zones as bonus
Maybe someone is using that combo or used it and can share some insights.
Thanks
Re: GoEdrum like HH Controler + Yamaha PCY-135 possible?
Can't see why not. The 2 components are essentially separate, it's the VSTi that figures out what sound to make with the information presented to it.
Not sure how edrumin will pick up the 3 zones though..?
anton
Post by anton »
MWJT42 wrote:Can't see why not. The 2 components are essentially separate, it's the VSTi that figures out what sound to make with the information presented to it.
Yeah, sounds logical.
Regarding the 3 zones. Don't know. like it is picking it up when connected as regular cymbal?
