Gewa G9 18" 3 zone ride cymbal
this is the wiring of a Gewa G9 18" 3 zone ride cymbal (piezo, switch, switch):
does that mean the edrumin would see it as a yamaha 3 zone with one cable?
Re: Zildjian LV converted test
I would say no. Looks like it has two separate outputs. You can make a special cable to gang the two output from a Roland style 3-Zone ride to a single Yamaha 3-Zone ride, though.
Ok, testing done, this cymbal works perfectly as 3 zone with one single cable set up as yamaha 3 zone, it is lightweight and 110€ cheaper than the atv 18“, only disadvantage is that it’s loud! It’s like hitting a bucket! Or it’s maybe because I didn’t mount it correctly on a cymbal stand because I’m using roland rack and the rod is too short For the stopper and felt, I need to get the right one
ayjaysmith
Re: Gewa G9 18" 3 zone ride cymbal
Post by ayjaysmith »
I’ve also been attempting to make a Yamaha-style 3 zone with Myrk membrane switches - where does the second lead from the edge trigger connect? I only see one going thru the resistor to the ring.
Forgive my lack of electrical knowledge. The bow and bell work, but I’ve either soldered something poorly or I’ve missed a connection altogether.
Both the edge and bell switch should connect to the ring, however the edge should got though a 10k resistor. I'm pretty sure the eDRUMin manual has wiring diagrams at the back.
@ajaysmith - please let us know your progress on this. I've been using Myrk membranes underneath on Pintech practice cymabls for choke only. I've been thinking about putting the membrane on top covered with foam.
ayjaysmith
I referenced the diagram which helped for the bell (membrane switch) and bow (piezo). My confusion was with the second “non-resistored”connection of the edge switch as it’s not drawn to show it linking up. I’ll try that, thanks!
ayjaysmith
No luck. I may give it another shot with a Roland style dual trs.
Probably better off just buying a Yamaha 135 in retrospect.
ayjaysmith
No luck with either the Roland or Yamaha methods. I don't want to hijack this thread with everything I tried unless OP is OK with it.
I ended up with a PCY135 and it's good to go.
