Go Edrum HiHat controller choice
thenewdrummer
Post by thenewdrummer »
I'm planning to do a diy hi hat with the goedrum controller and I need to buy one.
There's 3 versions of the controller Roland, Yamaha and Alesis.
My module is currently an Alesis but I'm planning using the controller with the eDRUMin.
Is there a version that would be better supported, or have more features that I should buy or any of them would work with the eDRUMin?
Re: Go Edrum HiHat controller choice
I think the Roland version would be the best fit.
thenewdrummer wrote:I'm planning to do a diy hi hat with the goedrum controller and I need to buy one.
I use the GHC, the Roland one, and it works fine.
thenewdrummer
I'll buy this one.
