Two zone snare piezo rim
TheJay
Post by TheJay »
Hey, when I hit the rim it triggers a crash cymbal noise even though I have it set to stereo and am not using a splitter. The snare triggers nicely when head is hit.
Re: Two zone snare piezo rim
What firmware version are you running? There's a crosstalk problem with version 1.2 but should be resolved in 1.3
TheJay
Post by TheJay »
I updated the firmware on all of them this morning before posting. I'm having the same problem with hi hat closing triggering crash noise too 50% of the time.
MIDI mapping issue?
TheJay
Post by TheJay »
The hi hat is set to hi hat and snare to snare within eDRUMin software.
And in the VST?
They often list a bunch of notes for the same articulation.
When I set up a new kit, I usually clean up all the extra notes per pad so I have no MIDI notes issues.
Are your crash and snare connected to the same ED4?
TheJay
Post by TheJay »
No, I have all the cymbals connected to one module and the snare is connected to the same one as three toms.
It's all on separate stands on top of a rug so no vibrations passing through either.
Are you monitoring using headphones or a loudspeaker?
I'm starting to agree with perceval. Sounds like a note assignment problem.
