Five modules, how to use them at the same time?
TheJay
Post by TheJay »
Hey Rob, is there a reason the eDRUMin software doesn't support more than four modules? Is that just the way the software is designed, so I could simply be updated or is there more to it?
Can you please help me get the fifth working at the same time?
If I had known a 10 port version was coming out, I would have waited.
Thanks.
Re: Five modules, how to use them at the same time?
It's not impossible for the Control Application to support 5 devices, it's just that there's not enough room on the UI for all the icons. It would be a significant amount of work to add support for more than 4 devices, and probably bug prone, so I'm not inclined to change that at the moment.
TheJay
Post by TheJay »
Thanks for your reply.
In that case, could you please help me to get the fifth one working at the same time? Is there a work around that you can think of?
anton
Post by anton »
For setting the edrumin up just setup four first, disconnect them and setup the fifth.
After you set everything up the control application does not have to run. Just your vst.
TheJay
Post by TheJay »
Thanks Anton.
