Can't find DSP Trigger in Cubase
hodini
Post by hodini »
Downloaded it but couldn't find the thing to try it out...
Re: Can't find DSP Trigger in Cubase
When you install, you can set the path where the VST is installed. Make sure you install it in your VST 2.4 path.
hodini
Post by hodini »
Now it's even more confusing, I can't find this vst 2.4 folder. Is that something that has to be downloaded ?
Nope. I haven't used Cubase in a while, but it should have two folders for VST plugins, one for VST 3 plugins and one for VST 2 plugins. I suspect if you go into the Cubase options, it'll likely have a setting for the paths.
hodini
Post by hodini »
So try the VST 2 plug in folder ? You'd think cubase would automatically check it when searching for new plug ins...
Absolutely it would if you install the plugin in the right folder. Steinberg is constantly changing the location of its default plugin folders. I'll send you a screenshot of the Cubase setting so you know where to find yours.
hodini
Post by hodini »
Thanks so much.
Here's where you can set the path. I recommend just reinstalling DSPT and using one of the paths already listed. Note that yours will likely look a bit different then mine.
hodini
Post by hodini »
Still no luck.
Well it's not a matter of luck. Send me the screenshot of your VST settings and I'll walk you through it.
