is it possible to use the edrumin hi-hat input as a midi-expression device (using a piano pedal) in conjunction with a keyboard midi controller? i use my edrumin for drums but i’m wondering if i can also use it, separately, as a midi expression device for this specific function with midi keys.
i have read these threads but they are not quite asking the same thing:
viewtopic.php?f=29&t=528&p=2285&hilit=M ... sion#p2285
viewtopic.php?f=29&t=583
thanks
edrumin for piano pedal
Re: edrumin for piano pedal
You certainly can.
Just plug in your sustain pedal and change it from 'bank change' to 'control change'. I think you'll want to have it send CC 64.
- dsteinschneider
I'm using one of my ED4's to add a second expression pedal to a midi controller
