Feature request: standard maximise / restore window buttons
I use a touch screen, and the GUI performs well for this when enlarged (especially editing response curves), but it's a little bit annoying that I have to resize the window manually.
Thanks!
Re: Feature request: standard maximise / restore window buttons
Maximizing is no problem, but restoring to the previous size is an issue. You've probably seen it. If you make the UI too small too quickly, some of the UI elements can disappear offscreen (the close button for example). It's a limitation of the graphics library I use (VSTGUI). To be honest, it annoys me too because I'm often working with my Surface Pro. I can probably find a workaround by animating the restore size process, but it's not elegant. I'll keep it in mind for a rainy day.
