I read through the manual, and I think I know which one to get but I want to be sure. I am using ableton 10, and what I want out of my pedals are to control Q filters for wah effect, pitchbend, volume, and I havent thought of a fourth purpose. My main question is can I just use the midi learn funtion on ableton to set up what I want and for it to save so that every time I load my ableton set it will be automatically loaded. Will the quattro do this or would I have to do the midi learn all over again? or will it save it? I dont want to get the midi din one if I dont have to. Also, does the quattro connect via one usb-c cable? or 4 seperate cables?
Thanks
Which model to get???
Re: Which model to get???
Ableton saves all its MIDI mapping with each project, so you only need to learn the assignments once.
The Quattro would serve you well. MIDI Expression devices with USB B connectors, so you would need a USB C to USB B cable or some form of adapter.
