Feature request: adjust pedal splash sensitivity
Firstly, my eDRUMin 10 arrived today, and what an amazing product. Total game changer for an A2E VSTi user like me.
I use SD3, and the pedal splashes are a notorious pain in the software (I have just turned off the CC triggered articulations in SD3).
I would like to trigger the pedal splash sound using the MIDI note sent by eDRUMin, but I'm getting lots of false hits sent during faster highhat foot playing.
I believe that there is a set time that a foot is down and then released by to trigger this note(?). Is it possible to make this value range set by the user to help mitigate these false hits?
For reference, I use a goedrum high hat controller.
Many thanks, Mike
Re: Feature request: adjust pedal splash sensitivity
I saw this from Rob in another thread... I’m already looking forward to 1.3. Foot chicks and splash have never been quite right for me.
viewtopic.php?f=29&t=668#p3574
I have found that chicks and splashes are much more responsive if you change the "Travel" value in the pedal editor.
70-80 seems to be the sweet spot for me for reliable triggering on a VH-10.
This feature is now available in the version 1.3 BETA.
viewtopic.php?f=29&t=680
