eDRUMin Control App Issue
ekuehnl
Post by ekuehnl »
I'm trying to connect the eDRUMin Control app to my computer using Network MIDI but I'm stuck.
Everything looks correct but the app won't move past the "Plug-In your eDRUMin message"
Thanks!
Network Midi Window
Network Midi Window
ekuehnl
Re: eDRUMin Control App Issue
Post by ekuehnl »
I figured it out. I usually attach a device to each of the MIDI interfaces in Audio Midi Setup so I can control which MIDI channels are visible in the DAW. That was screwing things up with the control app. Once I deleted the device so that only the eDRUMin Black interface was showing it worked right away.
Expect some crashes with version 1.1 of the iOS app. I have version 1.2 is TestFlight beta testing. It's much more responsive and stable. If you would like to use that, install the TestFlight app and email you appleID to support at audiofront dot net.
