I've searched the forum but haven't found what I'm looking for.
My old MPC 1000 has a pedal input, for which I use my KORG PS-1 momentary pedal to change sequence.
I now have a new MPC ONE, it doesn't have a pedal input, but it does have USB.
I'd like to run the KORG PS-1 through the MIDI expression and into the MPC ONE's USB input. Any thoughts on compatibility?
Any way I can check if it'll work before ordering a MIDI Expression?
Many thanks,
Mark
KORG PS-1 with MPC ONE
Re: KORG PS-1 with MPC ONE
Should work, at least according to their promotional material.
Fantastic, ordered!
Cheers.
Cheers.
