Preset: Yamaha PCY135 3-zone cymbal
Forum rules
Here's the preset I made for the Yamaha PCY135.
3-ZONE-PAD.hex.zip
(2.92 KiB) Downloaded 420 times
alder
Re: Preset: Yamaha PCY135 3-zone cymbal
Post by alder »
The manual says that you can load an .edp file type, but this is .hex?
Right. That's not a preset. It's a data dump from that pad.
Tkydon
Post by Tkydon »
what do we do with a Data Dump .hex file?
You don't do anything. Data dump files allow me to analyse the signal coming from a pad for debugging purposes.
Tkydon
Post by Tkydon »
Got it. Thx.
KirovHC
Post by KirovHC »
perceval wrote:
Thu Jul 16, 2020 3:35 am
3-ZONE-PAD.hex.zip
Hello,
so you can share with us some yamaha presets? 135 and 155 would be great!
