Problem with Superior Drummer 2.0 !??
mckaymental
Post by mckaymental »
Hi guys! I just build a A2E Drum kit and I have a problem with my cymbals.
I have a closed hi hat a ride and a crash. My hi hat is working properly but when I play my crash, sometimes the crash sound comes out and sometimes the ride sound comes out. Same with the ride.
I don't get why it does that. I've used the learn button in SD 2.0 and everything else is working great. I don't know why the two interfere with each other.
Can you guys help me with this one??
Thanks a lot! :)
Re: Problem with Superior Drummer 2.0 !??
You're using DSP Trigger? Depending on the input type you've selected, DSP Trigger can detect 3 different articulations for cymbals and output 3 different notes. What's probably happening is that one of the articulations on your ride, is mapped to the crash and vice versa. You can either turn off those articulations, or find a more appropriate note for DSP Trigger to output.
mckaymental
Thanks a lot! It solved that problem! :)
