Is support for Hi hat pedals on the cards?
The Roland VH-12 in particular?
Hihat pedal support
Re: Hihat pedal support
No, unfortunately there is no support at this point. I'm not sure what kind of technology the VH-12 uses, but I imagine it wouldn't work. I'll have to do a little research and get back to you.
Hello, is it now possible to use the hit hat vh-11 with your expression?
Is there any presents or cymbals loading settings in the latest version of a td9kx2 application?
Thanks in advance for the contact.
