Looking for advice on adjusting Positional Sensing
How should I set the position and width of the green bar in the Positional Sensing "widget" to make the center and mid center larger and the rim only for hits very close to the rim? The pad is a Ludwig 14" snare with a UFO Drums center mounted piezo and rim piezo mounted to the shell with a UFO angle bracket.
Maybe I should rephrase this question to - how do you adjust the green bar to make the outer "ring" smaller?
Thanks,
Re: Looking for advice on adjusting Positional Sensing
It really depends on the pad in question. The simple answer is to drag the right side of the green box close to the left side like in this pic. I made some changes to the positional sensing in version 1.0.1.6. What version are you using?
Annotation 2019-11-07 063200.png (6.7 KiB) Viewed 744 times
Interesting you mention you made changes in 1.0.1.6 because I upgraded several days ago. I'll follow your suggestion and see how that works for my pad. I understand that every pad is different, the idea I'll test is pulling the green bar over to the left more and making it more narrow.
Thanks,
Doug
I just copied the setting from your screenshot and it fixed the issue
