Which device for Roland Hi-Hat and CC messages
DanielM
Post by DanielM »
Hello.
Would one of the eDrumIn devices work with the following products?
Roland CY-5 Hi-Hat Pad
Roland FD-9 Hi-Hat Controller Pedal
Important for me is to get the MIDI CC messages depending on the Pedal pressure. Is that possible?
Thanks in advance for your efforts.
Re: Which device for Roland Hi-Hat and CC messages
Ya, eDRUMin supports both. The CY-5 plugs into one of the inputs on the front, and the FD-9 connects to the Hihat input on the back.
DanielM
Post by DanielM »
Thanks for getting back.
And I'll get CC4 MIDI messages from the pedal input?
If yes, can the CC number even be edited or is it fixed CC4?
The default is cc4, but you can set it to whatever you want. There are also settings to calibrate the pedal's range and adjust the responsiveness.
DanielM
Post by DanielM »
Sounds good. How much are the import duties to Germany? Any experiences about that?
I'm guessing it'll be about 25 Euros.
