kicks trigger pedals
motorizer
Post by motorizer »
hi Rob
Is there any chance to have a solution for plug kicks trigger pedals like roland kt10 in one of your devices?
Or do you plan to make it happen in the future? (it could be awesome)
thanks
Re: kicks trigger pedals
MIDI Expression devices do not support silent kick pedals like the Roland KT10. Trying to use that pedal is not good for the MIDI Expression nor is it good for the pedal.
As it so happens, I'm getting very close to releasing eDRUMin, which does support silent kick pedals and drum pads and triggers in general.
motorizer
Post by motorizer »
i receive today the midi expression quatro, can i send it back to you so i can purchase the edrummin module.
when do you think it will be available?
thanks
Sure, you can exchange it. eDRUMin should be available by the end of the month. If you want to return your MIDI Expression, can you contact me via a support ticket or simply reply to the one of the email your received when you made your purchase?
http://www.audiofront.net/contactSupport.php
motorizer
Post by motorizer »
sure!
