Number of CC messages
Sly
Post by Sly »
Hello,
I've got a project where I need to trigger many notes while pressing a hihat pedal. I can transform midi CC to midi note, but when trying to use a TD12 for exemple, I don't get enough midi CC04 message. The TD12 output only a few CC04 messages (only 3 or 4 messages from 0 to 127 if I press the pedal fast, a few more if I press it slowly, but still not enough).
Could you please tell me how many messages are sent by the midi expression from 0 to 127 when pedal is pressed fast ? When pressed slowly ?
Thanks
Sly
Re: Number of CC messages
Post by Sly »
Maybe it needs to be clarified.
When I press my hihat pedal, my drum module (roland TD-12 or Roland TD-30) output only a few midi CC messages.
Maybe someone can tell me if the midi expression (Quatro or IO) output more midi CC messages.
When I had a Roland TMC-6, I remember it outputs maybe 64 messages from 0 to 127, even if I press the pedal fast, that was far enough for my needs...
I'm interested in purchasing a Midi expression quatro but I don't want to return it because it don't suit my needs.
Thanks in advance
Hi Sly,
Sorry for the late reply. A hihat controller, when pressed quickly, goes from 0 to 127 in about 15 ms. The MIDI Expression throttles its MIDI messages to a maximum of 1 message every 4ms. So in 15 ms, you get about 3 or 4 messages. But that's pressing the pedal very hard. A less aggressive action would get you a lot more messages.
Sly
Post by Sly »
Thanks for your reply. I'll have to see if one message every 4ms is enough.
The Hihat value is measured once every 0.5 ms. The throttling is there to prevent swamping the MIDI port with excessive data.
There's a good chance that I'll make the number of values / second user definable in the next major update. That would allow you to get a lot more data from the pedal.
Sly
Post by Sly »
That would be great ! Thanks Rob
I'm now waiting for Edrumin and I'll buy a midi expression quattro + edrumin...
