Eventide H9
Simon
Eventide H9
Post by Simon »
Hi
I have bought a Midi Expression iO and want to connect it to Midi in in my Eventide H9 and connect a expression pedal. I have already a three button pedal aux switch connected and want to be able to use a expression pedal also connected to Midi in.
I have tried to connect it but the H9 don't respond.
Have you tested to connect the Midi Expression iO to an Eventide H9?
Best regards Andreas
Re: Eventide H9
Did you enable send pedal data to the MIDI Out DIN via the routing page? These should probably be set to on by default (note to self).
Andreas
Re: Eventide H9
Post by Andreas »
Okay. I will check this. Expression cc is 7 right or is it 11?
