Midi Expression macOS compatibility
N3M1C0
Post by N3M1C0 »
Hi everyone!
I was just looking for a way to connect only a sustain pedal on my computer (as the rest of my setup uses Bluetooth and does not offer a pedal input), and you guys at Audiofront seem to have the perfect solution for me :D
I just have one question, is macOS Sierra supported and is High Sierra planned to be?
Thank you a lot in advance,
Sincerely,
Charles
Re: Midi Expression macOS compatibility
You know, I just updated to Sierra yesterday, and everything seems fine. MIDI Expression devices are class compliant and the Control Application communicates using simple protocols that are baked into the foundations of USB. I suspect there will be no issue moving to High Sierra as well. On top of that, MIDI Expression is still being actively developed. so any issues that arise are can be handled swiftly.
