Trigger signal?
robald
Trigger signal?
Post by robald »
Hi Rob
Thanks again, i allready bought two midi expression's pedals
You've really change my life as a musician ;-)
I just want to ask a simple question that i can't find on forums:
Is there a way to plug a trigger pedal like a roland "KD7" into a midi expression with a 'magical' cable?
I mean, is ther a way to transform an electric message from a mono-jack and plug it into one of your pedals?
Thanks again for your work Rob
Best regards
Seb
Re: Trigger signal?
No, unfortunately trigger based controllers are not supported. I'm working on making a 'magic' device to do just that, but it's a long way off.
