Multiple instances of DSPTrigger to control one VI
mstrassheim
Post by mstrassheim »
Hello,
I have 5 triggers (5 audio tracks) and every track runs a instance of DSPTrigger (every trigger has a different midi-note. Is it possible to feed one single VI (ableton impulse) with my 5 triggers?
Regards, Markus
Re: Multiple instances of DSPTrigger to control one VI
Yes, it is. Open the editor for one of instances of DSPT. Click the 'Master' checkbox just above the image of the drum pad. After you do that, all MIDI data from all the instances of DSPT will be output by that single instance.
