positional sensing help
iainp999
Post by iainp999 »
Hi there,
I know that this is a topic that's had some coverage, but also that it can be specific to an individual's setup, hence my post.
I'm looking for some help in getting this working with a Drum-Tec Pro Snare and Superior Drummer 3.
I'm having a bit of trouble getting relatively consistent readings when trying to set the CC zone in the positional sensing graphic in the edrumin software i.e.
03-10-2025, 15-05-03.png (27.52 KiB) Viewed 29 times
I've settled on the above, but even when playing the drum, no matter what I seem to do either in the edrumin software or in the SD3 settings, I just can't seem to get a gradual progression from center to off-center to edge.
03-10-2025, 15-07-47.png (42.15 KiB) Viewed 28 times
Does anyone have any tips in terms of hardware/software adjustments that I could play around with?
Thanks in advance.
03-10-2025, 15-06-09.png (27.52 KiB) Viewed 29 times
iainp999
Re: positional sensing help
Post by iainp999 »
My software versions
03-10-2025, 15-09-55.png (35.74 KiB) Viewed 27 times
STP
Post by STP »
I am having the exact same issue with my Drum Tec Pro 3 snare!
The edge sound is also triggered in the center, did not figure this out yet!
Saw a person on the Toontrack site with the same problem.
I will keep you posted!
Greetings Steve
Drum-tec's 3-ply 'real feel' mesh heads are noisy and are known to cause issues with positional sensing on eDRUMin. If you have a 2-ply mesh head, the issue goes away. Alternatively some users report that adding a 25k resistor in series with the piezo helps resolve the issue.
