eDrumin 8: firmware up to date. Snare drum: mesh head, Yamaha DT50S dual zone side and - top mounted
Selected Mesh Side Piezo, input wiring mode: stereo input; Yamaha style wiring on (although no difference on or off for this issue).
Attached are 2 screenshots:
eDrumin_1 at startup;
eDrumin_2 when Calibrate is selected. Striking the drum, the threshold never moves and stays as shown?
I always use internal DIY triggers wirth eDrumin. This is something I wanted to try for my friend since I have top mounted triggers without getting involved making up internal triggering for him. Do you support top mounted triggers also?
Mesh-Top Side Mounted Trigger?
- eDrumin_1.png (318 KiB) Viewed 80 times
- eDrumin_2.png (321.76 KiB) Viewed 80 times
Re: Mesh-Top Side Mounted Trigger?
Ronyd wrote: ↑Thu Feb 13, 2025 3:09 pmeDrumin 8: firmware up to date. 14" x "5" Snare drum: mesh head, Yamaha DT50S dual zone side and - top mounted; no bottom head.
Ronyd wrote: ↑Thu Feb 13, 2025 3:22 pmRonyd wrote: ↑Thu Feb 13, 2025 3:09 pm
macOS Sequoia; mac Studio M1
1. eDrumin_2 when Calibrate is selected. Striking the drum, the threshold never moves and is also sending rapid fire hit messages as shown (this also happens using internal trigger)?
I always use internal DIY triggers with eDrumin. This is something I wanted to try for my friend since I have top mounted triggers without getting involved making up internal triggering for him. Do you support top mounted triggers also?
The calibrate thresh issue should be fixed in build 31. Can you please indicate your exact firmware version.
