I have the rooms of Superior Drummer 3 and want to use the sounds from "The rooms of Hansa" in my kit.
The ride has great sounds but shows as 8 different sounds in SD3.
Is there a way to use them all?
I am using a Lemon 20 (and 18) 3 zone ride with the Yamaha adaptor to 1 cable.
Do I have to pick 3 of the sounds?
I am also not seeing an easy way to assign the sounds to different notes easily, am I missing something?
Is there a way to assign all those secondary notes??
Thanks!!!
Multiple ride sounds on a 3 zone ride in SD3
- 02-07-2025, 22-52-51.png (398.94 KiB) Viewed 291 times
- 02-07-2025, 22-47-25.png (235.28 KiB) Viewed 293 times
- 02-07-2025, 22-45-59.png (412.01 KiB) Viewed 293 times
Re: Multiple ride sounds on a 3 zone ride in SD3
You have to pick 3, bell, tip and edge.
Bow tip 1, whether it is #54, 59, 84, 87,... is all the same sound. So, pick a note and stick with it.
When you start having a bigger kit, all those redundant midi notes would drive me nuts, as they would go over to other pads.
I used to clean up my SD3 map to have single notes for each pads, deleting all the extra rigger notes, so if I needed to add another pad and sound, it wouldn't trigger two sounds.
No doubt, I am just realizing that, so click on the snare and all the notes that light up in blue are used right?
Then delete the duplicates?
For example the snare, I have tons of "snares" light up....
(there isn't an auto clean up is there?)
- 02-08-2025, 00-45-46.png (249.44 KiB) Viewed 282 times
unfortunately... no auto-clean!
Oh boy, how do I clear mappings? If I try to clear in the main window right side "midi mapping keys" there is no option to do so.
If I do it in the edrums page it doesn't stick???
For those wondering, I finally figured it out.
You can change the midi numbers here!
- 02-12-2025, 05-53-39.png (70.97 KiB) Viewed 231 times
