Hi
I've recently been experiencing strange behavior when opening mine Control Application.
When I open the app, not all parameters appear and the inputs are no longer occupied, see Figure 1.Only when I move the image a little with the left mouse button does everything appear as desired. What could that be?
Only when I move the image a little with the left mouse button does everything appear as desired, see Figure 2.
What could that be?
Thank you!
Christian
Error opening the Control Application?
- 1.jpg (200.21 KiB) Viewed 17 times
- 2.jpg (216.24 KiB) Viewed 17 times
Re: Error opening the Control Application?
If you make the UI a bit smaller so that it's a bit smaller than your physical display, does the problem go away?
Hi Rob, I think that's it thanks!
