edrumin 8 or 10?
markratnam
edrumin 8 or 10?
Post by markratnam »
I counted the pad/cymbal inputs on my kit and I require a total of 15 inputs running into EZdrummer 3.
I would just like to confirm that I can purchase two sets of eDrumin 8 and connect both together to run into my Mac via USB?
Reason I am asking is because the difference between the eDrumin 8 and eDrumin 10 is that the Edrumin 10 has a MIDI in/out while the eDrumin 8 only has MIDI out.
Just wanted to confirm that I connect one eDrumin 8 to the other eDrumin 8 via the USB host (USB B port from one device into the USB A port of the 2nd eDrumin 8) and then from the 2nd eDrumin 8 using the USB B (printer port) to connect to my Mac.
Is this flow correct? Thank you for your time and inputs. I am so afraid of making an incorrect purchase only to regret later.
Re: edrumin 8 or 10?
markratnam wrote:
Tue Jan 14, 2025 4:21 am
That's correct.
