Following my previous posts where I shared the packages/dependencies needed to run eDRUMin on both Arch Linux and OpenSUSE Tumbleweed (should also run on other OpenSUSE derivatives like Leap and Slowroll), I have decided to test the waters with Fedora.
As I stated in my previous posts, I was a bit sad that if I needed to use this fantastic tool to setup my edrummin modules, I would be forced to run a Debian-based distro, I decided to investigate the packages needed on other Linux distros, given that not everyone uses Debian/Ubuntu, and actually there are a lot of musicians and sound engineers on other distros.
Fedora is one such cases, where there are people on the COPR comunity developing solutions for audio production, and also Fedora has the Fedora JAM spin that basically is a tailored version of Fedora that comes ready out of the box for recording and music production.
So, once again, and with help of people in Discord, I managed to track down the equivalent packages on Fedora:
Code: Select all
sudo dnf install xcb-util-cursor-devel libusbx-devel
Code: Select all
[pdf=factory"
echo "Installation complete."
]#!/bin/bash
# GET SUDO privilege (Change sudo to gksu or gksudo if you prefer a graphical prompt)
echo "***********************************************"
echo "* eDRUMin Control Setup *"
echo
echo "This installer requires root privileges..."
[ "$UID" -eq 0 ] || exec sudo bash "$0" "$@"
#install dependencies
APP_NAME="eDRUMin"
VST3_NAME="edrumin.vst3"
SHORTCUT_NAME="${APP_NAME}.desktop"
BINARY_NAME="${APP_NAME}"
APP_INSTALL_FOLDER="/opt/${APP_NAME}"
USER_HOME=$(getent passwd $SUDO_USER | cut -d: -f6)
SHORTCUT_PATH="/usr/share/applications/${SHORTCUT_NAME}"
RULES_PATH="/etc/udev/rules.d/${APP_NAME}.rules"
PDF="${APP_NAME}.pdf"
ICON_NAME="icon.png"
AF_SETTINGS_PATH="${USER_HOME}/.AudioFront"
ICON_PATH="${AF_SETTINGS_PATH}/${APP_NAME}/${ICON_NAME}"
SETTINGS_PATH="${AF_SETTINGS_PATH}/${APP_NAME}"
#REMOVE OLD STUFF
if [ -d "${APP_INSTALL_FOLDER}" ]; then
echo "Uninstalling previous version..."
rm -r "${APP_INSTALL_FOLDER}"
fi
#create application folder
mkdir -p "${APP_INSTALL_FOLDER}"
echo "Creating folder structure..."
#make firmware folder
mkdir "${APP_INSTALL_FOLDER}/firmware"
mkdir "${APP_INSTALL_FOLDER}/vst3"
#copy the binary
echo "Copying application binaries..."
cp "./bin/${BINARY_NAME}" "${APP_INSTALL_FOLDER}"
cp -r "./bin/${VST3_NAME}" "${APP_INSTALL_FOLDER}/vst3/"
#copy the firmware
echo "Copying firmware..."
cp -r "./firmware" "${APP_INSTALL_FOLDER}/"
echo "Creating Desktop shortcut..."
echo "[Desktop Entry]" > "${SHORTCUT_PATH}"
echo "Type=Application" >> "${SHORTCUT_PATH}"
echo "Terminal=false" >> "${SHORTCUT_PATH}"
echo "Name=eDRUMin" >> "${SHORTCUT_PATH}"
echo "Icon=${ICON_PATH}" >> "${SHORTCUT_PATH}"
echo "Exec=${APP_INSTALL_FOLDER}/${BINARY_NAME}" >> "${SHORTCUT_PATH}"
echo "StartupNotify=true" >> "${SHORTCUT_PATH}"
echo "StartupWMClass=eDRUMin" >> "${SHORTCUT_PATH}"
chmod 755 "${SHORTCUT_PATH}"
chmod +x "${SHORTCUT_PATH}"
chmod -R 777 "${APP_INSTALL_FOLDER}/firmware"
echo "Adding udev rules..."
if test -f "$RULES_PATH"; then
rm "${RULES_PATH}"
fi
touch ${RULES_PATH}
echo "# eDRUMin rules to allow access to rawhid devices" >> "${RULES_PATH}"
echo "SUBSYSTEMS==\"usb\", ATTRS{idVendor}==\"16c0\", ATTRS{idProduct}==\"0460\", MODE:=\"0666\"" >> "${RULES_PATH}"
echo "SUBSYSTEMS==\"usb\", ATTRS{idVendor}==\"16c0\", ATTRS{idProduct}==\"0461\", MODE:=\"0666\"" >> "${RULES_PATH}"
echo "SUBSYSTEMS==\"usb\", ATTRS{idVendor}==\"16c0\", ATTRS{idProduct}==\"0462\", MODE:=\"0666\"" >> "${RULES_PATH}"
echo "SUBSYSTEMS==\"usb\", ATTRS{idVendor}==\"16c0\", ATTRS{idProduct}==\"0463\", MODE:=\"0666\"" >> "${RULES_PATH}"
echo "SUBSYSTEMS==\"usb\", ATTRS{idVendor}==\"16c0\", ATTRS{idProduct}==\"0464\", MODE:=\"0666\"" >> "${RULES_PATH}"
echo "SUBSYSTEMS==\"usb\", ATTRS{idVendor}==\"16c0\", ATTRS{idProduct}==\"0465\", MODE:=\"0666\"" >> "${RULES_PATH}"
echo "SUBSYSTEMS==\"usb\", ATTRS{idVendor}==\"16c0\", ATTRS{idProduct}==\"0478\", MODE:=\"0666\"" >> "${RULES_PATH}"
udevadm control --reload
#MAKE AUDIOFRONT FOLDER IF IT DOESN'T ALREADY EXIST
if [ -d "${AF_SETTINGS_PATH}" ]; then
echo "AudioFront Folder found..."
else
echo "Creating AudioFront folder..."
mkdir "${AF_SETTINGS_PATH}"
chmod 777 "${AF_SETTINGS_PATH}"
fi
#MAKE THE APPLICATION SETTINGS PATH
if [ -d "${SETTINGS_PATH}" ]; then
echo "Application settings folder found..."
else
echo "Creating application settings folder..."
mkdir "${SETTINGS_PATH}"
chmod 777 "${SETTINGS_PATH}"
fi
if test -f "${USER_HOME}/.AudioFront/${PDF}"; then
echo "Removing previous user manual..."
rm "${USER_HOME}/.AudioFront/${PDF}"
fi
echo "Copying user manual..."
cp "./${PDF}" "${USER_HOME}/.AudioFront/"
chmod 777 "${USER_HOME}/.AudioFront/${PDF}"
echo "Copying application icon..."
cp "./${ICON_NAME}" "${SETTINGS_PATH}"
chown $SUDO_USER "${ICON_PATH}"
chmod 777 "${ICON_PATH}"
echo "Copying factory presets..."
cp -rf "./presets/factory" "${SETTINGS_PATH}"
chown -R $SUDO_USER "${SETTINGS_PATH}/factory"
chmod -R 777 "${SETTINGS_PATH}/factory"
[/pdf]
Hope you Fedora users enjoy and happy drumming!
