I'm blown away by the edrumin 10. AD2 had a sale so I finally got some kits so I filled the edrumin 10 with my alesis strike pro. Before I was using the demo so I only used my snare and hihat with the edrumin and mixed the rest of the alesis kit to my headset.
Ride,
I thought I broke my strike ride, I got bell hits on bow without changing any settings so I thought I smashed the sensor, but I don't have this issue with the edrumin. However, the bell and edge are swapped. For now I changed samples in AD2 but I would like the edrumin to send the right signal so what settings should I look at?
Floor 2,
I have 2 floor toms set in the edrumin software, but the midi note for first floor tom is sent for both floor toms (note 67 off the top of my head). Again, to fix this for now I changed the second floor to the finger snap and assigned the low floor sound to that note in AD2. But it's the same note so without changing the kit piece I couldn't change the sound in AD2.
Lastly, I don't feel any dynamics currently, most likely a misunderstanding of settings on my end too. Velocity range 1 to 40 sound the same which is a too big range. No matter how I change the curve, it's always too loud below up to 40.
Couple issues using alesis strike and addictive drums
Re: Couple issues using alesis strike and addictive drums
What pad type is it set too? If you are using the the Roland 3-zone cymbal, perhaps you have the 2 cables swapped. If you are using the Yamaha 3-zone pad type, then there's a button to swap the bell and edge notes.WAY3D wrote: ↑Mon Jan 06, 2025 12:35 pmI thought I broke my strike ride, I got bell hits on bow without changing any settings so I thought I smashed the sensor, but I don't have this issue with the edrumin. However, the bell and edge are swapped. For now I changed samples in AD2 but I would like the edrumin to send the right signal so what settings should I look at?
Does addictive drums have 2 floor toms? Is this perhaps a bug with eDRUMin's AD2 drum map?I have 2 floor toms set in the edrumin software, but the midi note for first floor tom is sent for both floor toms (note 67 off the top of my head). Again, to fix this for now I changed the second floor to the finger snap and assigned the low floor sound to that note in AD2. But it's the same note so without changing the kit piece I couldn't change the sound in AD2.
Take a look at this video:
https://youtu.be/v9_w32TWKZ0
Thanks for the reply! I
The ride was on Roland 3 zone. I've tried swapping cables but it wouldn't register a bell at all. I've set it to the yamaha setting and now choking it also works!
Edrumin is set to AD2 map, AD2 has a 4th (and even 5th, or at least in samples) tom. I could manually map the 4th Tom to the finger snap you provided in the edrumin software. But when i select 2nd floor, both my 1st and second floor produce note. Sadly I can't upload the video explaining it better as it's too big..
I will have another look at the video for dynamics settings, thanks!
