Flamming notes using Bt-1 preset
owenthesheppard
Post by owenthesheppard »
Hi guys,
In general I’m looking for the best settings to use BT-1 triggers on the edrumin8
I have an electronic drum kit that uses many Bt-1 triggers and when testing the edrumin8 I was getting flammed notes a lot, regardless of tweaking many of the settings.
When plugging the same triggers in to Roland native trigger modules this issue does not persist.
Any help is appreciated
Gnasher
Re: Flamming notes using Bt-1 preset
Post by Gnasher »
I have the BT-1 with an eDRUMin 10 unit. No issues.
Have you tried adjusting the decay?
I suspect you just need to dial in the transient scanning controls. Have you watched this yet?
https://m.youtube.com/watch?v=v9_w32TWKZ0
