Sample Pad to 2 eDRUMin 10 modules
CodaClef
Post by CodaClef »
Pieces are arriving slowly!
I finally have the 2 eDRUMin 10 modules to use with my Alesis Sample Pad Pro, a hi-hat, double kick and 2 toms.
While I wait for the rest of the pieces I am starting to setup the devices.
Can anyone let me know if 1 of the options in the diagram os better than another? If 1 of them won't work, or a better way?
Thanks!
Drum Kit v2.jpg (109.34 KiB) Viewed 127 times
Re: Sample Pad to 2 eDRUMin 10 modules
I would go with the second option. A third option would be to connect a hub to the host port of one of the eDRUMins and then connect the Alesis and 2nd ED10 to the hub.
