Tell me my EDI4 isn't just dead.
i420piate
Post by i420piate »
I noticed a firmware update was out for the EDI4 and EDI8 (I forgot about not doing it through a hub), but the update worked. But after it the EDI4 was randomly disconnecting. so then unplug it and replyg it again and I went to downgrade the EDI Mac OS Control app and subsequent downgrading of firmware on each unit. The progress started and then the app just said "plug in your eDRUMin", I can't get this unit to even show power now. I plugged it into the USB in Windows and a Mac, but nothing, read that the 9v jack uses BOSS style 9v polarity, unplugged power from my DS-1 Distortion pedal and plugged it into the eDRUMin4 hoping to see some form of power LED light up, ...and nothing. Dear God I hope there is some way to reflash the firmware. Has anyone else had this issue? I've searched the forums for "reset" "hard reset" and such... :cry:
Alesis Surge w/ 5 tom pads, an A2E kids 16" kick, 6 Alesis 10" 1-zone w/ choke cymbals, Lemon 12" 2-zone 2pc hihat, and a 15" 3-zone ride into an EDI8+EDI4+Surge module using SD3/SSD5.5 in Logic on a Mid-2015 MBP with Mac OS Sequoia.
Re: Tell me my EDI4 isn't just dead.
There should be a file called MEC_Log.txt on your desktop. Can email that to support at audiofront dot net and I'll help you recover the device.
i420piate
Post by i420piate »
Email sent. Thanks!
