MIDI Expression 2.9.5 BETA available
MIDI Expression 2.9.5 BETA is now available for testing. Because of many under-the-hood changes in version 2.9.5, downgrading will result in your device being factory reset, so I'd advise anyone testing this version out to first make a snapshot of your device before updating so that you can get your old settings back should you need to downgrade.
New Features
  • Added sub-modes for sustain / footswitch type pedals so that most modes with press/release, short press/long press, and inc/dec sub-modes.
  • Switch type pedals can now control transformer transpose and transformer channel.
  • 7bit or 14bit parameter values can be inserted into sysEx messages and all pedal types can now send them.
Improvements
  • UI cosmetic / layout / organization improvements.
  • Reduces switch type processing latency / jitter to less than 0.5ms.
  • Improved support for StudioLogic SLP3-D.
  • Improved support for rotary encoders.
  • Parameter feedback support for 14bit CC.
  • Parameter feedback improvements when using transformer.
  • Updated the manual.
  • Lots of small bug fixes.
ME_Control_PC_2.9.5.16.zip
ME_Control_OSX_2.9.5.16.zip
ME_Control_LINUX_2.9.5.16.zip
11-19-2024, 16-25-20.png (223.58 KiB) Viewed 1634 times
11-19-2024, 16-23-59.png (46.4 KiB) Viewed 1634 times
11-19-2024, 16-30-29.png (139.12 KiB) Viewed 1632 times
stub
Re: MIDI Expression 2.9.5 BETA available
Post by stub »
On another MIDI switch product I've seen a feature called "Long Release" where the button sends a different message(s) if the release is preceded by a long press than it does if the release is preceded by a short press (short release). It's kind of clever.
Another feature I've seen is the ability to send multiple events from one button press (or release), and in another scenario, there can be a series of numbered button presses, i.e., the first press does action 1, the second press does action 2, and the third press does action3, etc. Cycling through those.
I know these add complication to an otherwise clean & simple UI. However, in all these cases, they are nice ways to get more functionality out of one button/input.
No pressure, just mentioning it.
Changes in build 3
  • Fixed an issue with 3-Port MIDI Expression iO with USB-B connector that was causing it to show up as only having 1 input. The issue was also present in version 2.9.4 firmware.
Changes in build 5
  • Fixed/improved parameter feedback when pedal MIDI is being transformed.
  • Fixed an issue saving / recalling toggle state of 2nd button of footswitch.
Changes in build 9
  • Added parameter feedback support for 14bit Control Change.
  • Bug fixes with parameter feedback and MIDI transformer.
  • Fixed 14bit CC sending MSB / LSB out of order.
Posted build 15 to fix issue connecting to iOS Control Application.
I posted build 16 to fix loading device snapshots.
stub
Post by stub »
Thanks for including all the new features!! The increment/decrement is super useful!!
